Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Mix stream issue
david_c_1
I noticed that if I try to mix a stream in the successful callback of its publish api, I get the following error:
Invalid stream found in targetStreams
To try to fix the problem I use a timeout that is sometimes insufficient (what delay should I set?).
Here my code:
M.conference.publish(M.aStr, { maxAudioBW: 100 }, function(st){
            var mixedStreams = [];
            mixedStreams.push(M.mixStr);
            setTimeout(
                              function(){
                                     M.conference.mix(M.aStr, mixedStreams,
                                                 function () {
                                                       M.log(M.INFO, "Success on mix audio share screen ", "");
                                                 }, function (err) {
                                                       M.log(M.INFO, "Failure on mix share screen ", err);
                                },500);
Jianjun_Z_Intel
Hi david,
The error message means there is at least one element in mixedStreams is not Woogeen.ExternalStream. Could you please check the type of M.mixStr before calling mix?
