Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
RTMP support
Mid_J_
Hello Team,
1. Is there a way to Output RTMP or HLS stream from the Mixed Video MCU conference mode?
2. Or is any there way to ingest the raw mixed stream to FFMPEG
MJ
Qiujiao_W_Intel
Hi, Mid,
For question 1:
Yes, we support to output MCU mixed video stream to both rtmp server and HLS server. The recommendation is to output MCU mixed video stream to rtmp server, and do hls streaming on rtmp server side.
For question 2:
Yes, once output MCU mixed video stream to rtmp server, you can use ffmpeg to access it through rtmp server
Mid_J_
I tried using
 conference.addExternalOutput('rtmp://MYRTMPSEVER:1935/mystream', {streamId:"live3"
  }, function () {
    L.Logger.info('Start external streaming success.');
  }, function (err) {
    L.Logger.error('Start external streaming failed:', err);
But i get err err = "Timeout to make rpc to avstream.cfac4dd7-7584-ac22-62f0-527b2e12ce6d.0.subscribe
on client side and get the attached error on server side
2017-10-12 12:48:24.412  - WARN: AmqpClient - Late rpc reply: { data:
   { type: 'failed',
     reason: 'avstream_out fatal error: No a/v options specified' },
  corrID: 72250,
  type: 'onStatus' }
Full log during the connection is attached
Please check
Qiujiao_W_Intel
Hi, Mid, please double check your code, for addExternalOutput API,
  }, function () {
  }, function (err) {
url should be: rtmp://MYRTMPSEVER:1935/applicationname/streamname, and streamId should be stream id you want to push (MCU mix stream id or forward stream id), one of our sample:
conference.addExternalOutput('rtmp://MYRTMPSEVER:1935/liveshow/rtmptest', {streamId:"59c9ad8bfb585823cd28a230-common"
  }, function () {
  }, function (err) {
Another notice is that currently we don't support adding external output for audio only or video only stream, please double check your code and stream
Mid_J_
Thanks a lot for your reply.
I tried with Multiple RTMP servers with correct application name and stream name.
But I am still getting below results - Better results now for RTSP than RTMP but still not able to get it working.
I am using version Release version 3.3.1
ffmpeg -v
ffmpeg version 3.1.2
I only initiate this call after trySubscribeStream and only after I am able to view the mix stream properly.
I am using default Both audio video with default camera and not trying to use only audio or video
I have again attached the error log from server side
===== RTMP ==================
streamvar = {
streamId: stream.id(),
resolution: {width: 640, height: 480}
conference.addExternalOutput("rtmp://MYRTMPSERVER:1935/applicationame/livestream", streamvar , function () {
console.log('Start external streaming success.');
  }, function (err) {
console.log('Start external streaming failed:', err);
Client side "Start external streaming failed: Timeout to make rpc to avstream.89b1d28e-72e5-3653-2946-ef0663ee4606.0.subscribe"
Server Side "2017-10-27 15:02:47,651  - ERROR: woogeen.RtspOut - No a/v options specified
2017-10-27 15:02:47.651  - ERROR: AccessNode - avstream-out fatal error: No a/v options specified"
Am I using it wrong for this version?
=====RTSP ===================
When I try using RTSP "rtsp://MYRTMPSERVER:1935/applicationame/livestream" I get below results
I even get stream in my RTMP/RTSP server for few seconds but after few seconds it disappears.
On Client Side: "Start external streaming success."
On Server Side:
2017-10-27 15:31:24.181  - INFO: Portal - Fault detected on node: { agent: 'avstream.89b1d28e-72e5-3653-2946-ef0663ee4606',
  node: 'avstream.89b1d28e-72e5-3653-2946-ef0663ee4606.2' }
2017-10-27 15:31:24.183  - INFO: SocketIOServer - addExternalOutput onConnection error: access node exited unexpectedly
I have attached logs of both RTMP and RTSP.
Please let me know what could be the issue?
For Remove Output when using below call
conference.removeExternalOutput( "rtsp://MYRTMPSERVER:1935/applicationame/livestream", function () {
console.log('Stop external streaming success.');
  }, function (err) {
console.log('Stop external streaming failed:', err);
If I use direct string as param conference.removeExternalOutput( "rtsp://MYRTMPSERVER:1935/applicationame/livestream"
    I get error msg "Stop external streaming failed: Invalid RTSP/RTMP server url"
If I use Json object conference.removeExternalOutput( {id:"rtsp://MYRTMPSERVER:1935/applicationame/livestream"}
    I get "Stop external streaming failed: URL should be string."
Kindly have a look. Please let me know if I am using it wrong.
Note from the documentation it says to use below
<script type="text/JavaScript">
var conference = Woogeen.ConferenceClient.create();
conference.addExternalOutput(url: 'rtsp://localhost:1935/live', {streamId: xxx
}, function () {
  }, function (err) {
</script>
"conference.addExternalOutput(url: " this gives JS error
conference.removeExternalOutput({id: rtspIdToStop}, function () {
    L.Logger.info('Stop external streaming success.');
  }, function (err) {
    L.Logger.error('Stop external streaming failed:', err);
</script>
What is rtspIdToStop
Appreciate your help.
