Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Need to add i915.alpha_support=1 to GRUB file?
Chandramouli_P
Below is the environment details:
Operating System: Ubuntu-18.04.2
Kernel Version: 5.2.7-050207-lowlatency
Model Name: Intel(R) Core(TM) 8th Gen i5-8400 CPU @ 2.80GHz (6 Cores)
RAM: 4 GiB DDR4
Intel OWT version: 4.2.1
When installing OpenVINO toolkit, do I need to add "i915.alpha_support=1" to GRUB configuration file? Because, my kernel version is greater than 4.14 version. Please confirm.
Thank you.
Chandramouli.
Qiujiao_W_Intel
Is there any problem when adding i915.alpha_support=1 to /etc/default/grub file? We didn't add this setting in our 5.0.0-37-generic kernel manually when installing OpenVINO and it works well.
Chandramouli_P
Hello Team,
Any update would be appreciated.
Thank you.
Chandramouli.
Chandramouli_P
Hello Team,
Any help would be appreciated.
Thank you.
Chandramouli.
Chandramouli_P
Hello Team,
Thank you.
Chandramouli.
Chandramouli_P
Hello Team,
Thank you.
Chandramouli.
Qiujiao_W_Intel
Which OpenVino version do you install? You should follow related software requirement by OpenVINO.
Chandramouli_P
Hello Qiujiao,
Thank you for your reply. We are using the latest version of OpenVINO (l_openvino_toolkit_p_2019.2.275). As per the recomondations, If we use 8th Generation Intel® Core™ processor, we will need to add i915.alpha_support=1 to /etc/default/grub file.
Thank you.
Chandramouli.
Chandramouli_P
Hello Team,
Thank you.
Chandramouli.
Qiujiao_W_Intel
Chandramouli_P
Hello Qiujiao,
Thank you for your reply. If we do not add also, we haven't faced any issues.
Thank you.
Chandramouli.
