Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
New builded iOS OWT.framework & WebRTC.framework, join meeting crash
Jeremy_Jiang
With the original iOS OWT.framework & WebRTC.framework & libsioclient_tls_no_verification.a in CS_WebRTC_Client_SDK_iOS.v4.2, I could join meeting successfully.
Then I checked out latest code from master (https://github.com/open-webrtc-toolkit/owt-client-native), built out new iOS OWT.framework & WebRTC.framework.
However, with the new builded iOS OWT.framework & WebRTC.framework, when join meeting, it crashed. Seems it's related with socket.io tls handshake.
I tried to rebuild a new socket.io .a, unfortunately, not successful.
Any suggestions? Many thanks.
Crash Information:
Crash Information
Jeremy_Jiang
After some tries, I built out libsioclient.a (tls) successfully.
However, when join meeting, socket url like: wss://xxx.xxx.com/socket.io/?EIO=4&transport=websocket
crashed here:
YanbinZ_Intel
Hi, Jeremy
  Do you use v4.2.1 version? You may need use v4.2.x branch to update source code.   Master and v4.2.x use different webrtc stack .
Yanbin
sharma__sumit
Hi Team,
I am also facing the same issue.
Similar to Jeremy, I also built and used the latest frameworks from master branch (v4.3) and getting crash while joining a conference at following line
!ret->x509_method->ssl_ctx_new(ret.get()))
Kindly help as this is a major blocker.
Things were perfectly fine with 4.2, before upgrading.
sharma__sumit
Hello Team,
Any update on this?
Thanks in anticipation.
sharma__sumit
Hello Team,
Any update on this?
Its critical!
Sumit
Jeremy_Jiang
sharma,
I managed to work, try to build libsioclient.a (tls) yourself, I guess the default openssl in libsioclient_tls.a removed some
deprecated functions.
Reference: https://github.com/openssl/openssl/issues/6565
1. So I just git download OpenSSL-for-iPhone:
git clone --recurse-submodules https://github.com/x2on/OpenSSL-for-iPhone
2. and cd into /Your-local-Path/xx/depot_tools/OpenSSL-for-iPhone directory, then execute:
./build-libssl.sh --version=1.1.0f --deprecated
3. then build your own OWT.framework & WebRTC.framework, specify
python3 /Your-local-Path/xx/depot_tools/src/scripts/build.py --scheme release --arch arm64 --ssl_root /Your-local-Path/xx/depot_tools/OpenSSL-for-iPhone --skip_tests
