Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
OMS Native SDK Build Script
Matsuzawa__Tomohiro
I created the OMS Native SDK Build Script for Android with Docker so that you can easy to build it on PC or Mac.
(You’ll need a Linux development machine for building WebRTC library.)
https://github.com/thmatuza/oms-native-sdk-build-docker
Feedback and suggestions are greatly appreciated. Thanks!
Tomohiro Matsuzawa
He_Z_Intel
Looks good Tomohiro! Thanks for what you have done :)
I'd like to ask a question if you don't mind, as i am not very familiar with docker, how would you update the code and re-compile all the libraries?
Matsuzawa__Tomohiro
Hi Hank,
Whenever you run build.sh, it run all commands written in Dockerfile because it specify --no-cache
https://github.com/thmatuza/oms-native-sdk-build-docker/blob/master/build.sh#L3
It checkouts and sync.
https://github.com/thmatuza/oms-native-sdk-build-docker/blob/master/build/Dockerfile#L5
Therefore, it updates the code and re-compile all the library whenever you run build.sh.
Does it make sense?
Jianjun_Z_Intel
Tomohiro, thanks for your contribution.
