Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
OpenCL is required for Intel CS for WebRTC?
Chandramouli_P
Do we need to install OpenCL to work with Intel CS for WebRTC framework? Is there any dependency to use some additional features which is providing by Intel CS for WebRTC framework?
Thank you.
Chandramouli.
Hr__Z
https://software.intel.com/sites/products/documentation/webrtc/conference/
6.1.2 Building Existing Plugins
A few sample plugins are shipped with OWT server. After you build and install OWT server, the source of those analytics plugins will be placed under analytics_agent/plugins/ directory.
Before you build those plugins, you need to install Intel Distribution of OpenVINO 2018 R5 from https://software.intel.com/en-us/openvino-toolkit/. After installation, make sure you go to /opt/intel/computer_vision_sdk/install_dependencies/ directory, and run: sudo -E ./install_NEO_OCL_driver.sh
Intel Distribution of OpenVINO 2018 R5 will require Intel Core 6th to 8th Generation with Intel HD graphics or Iris(Pro) graphics for inferencing on GPU with OpenCL as the backend. The supported OSes are Ubuntu 16.04 and higher, or CentOS 7.4 or higher. Make sure your hardware/software configuration is correct before building and deploying the sample plugins.
To build the plugins, simply go to analytics_agent/plugins/sample directory, and run: ./build_samples.sh
Copy all files under build/intel64/Release/lib/ to analytics_agent/lib/ directory, or to the libpath as specified in agent.toml in analytics_agent.
Chandramouli_P
Any update would be appreciated.
Thank you.
Chandramouli.
Chandramouli_P
Hello Team,
Thank you.
Chandramouli.
Hr__Z
Chandramouli_P
Thank you very much for your detailed reply.
Chandramouli.
