Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Overconstrained Error
david_c_1
Hi team,
I have a problem when starting a localstream.
I get an OverconstrainedError when I try to close a stream with a lower resolution and I attempt to start a new stream with a higher one on the same device.
Instead, starting a stream with a higher resolution and than trying to change to a lower one doesn't return errors.
How can I fix this problem?
David
Jianjun_Z_Intel
Hi David,
OverconstrainedError indicates a source cannot conform the constraints specified. It's usually thrown by browsers.
