Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Problem with creation of Managed C++ .NET wrapper for woogeen library.
htnik_h_
I am currently creating .NET wrapper for woogeen library in Visual Studio 2015. I created a C++ managed .NET assembly for this, but the probkem is what supplied libraries  woogeen-debug.lib and woogeen-release.lib compiled whith static linking flags. Managed C++ assembly have to be compiled as DLL, but then I try to complie it as DLL it produce following errors:
woogeen-release.lib(sample_utils.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MT_StaticRelease' doesn't match value 'MD_DynamicRelease' in WoogeenNet.obj
plus a lot of linker arrors about missing symbols (WoogeenNet.obj is produced from my managed C++ WoogeenNet.cpp file).
The project can be successfully compiled as static library, but static library can't be added to C# WPF project. Is it possible to create additional version of woogeen library with dynamic linking?
I have limited deadline for this projects.
htnik_h_
Also, the woogeen library is 32 bit only. 32-bit code may be very slow just because of small number of registers. Why 64-bit library is anavailable?
Naresh_R_1
Yes its the same issue we are facing with
Environment:
Windows 7 64 Bit, Microsoft Visual Studio 2015, QT Plugins Installed
Error    LNK2038    mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MT_StaticRelease' in conferencesampleqt.obj    ConferenceSampleQt    D:\CS_WebRTC_Client_SDK_Windows.v3.2.1\samples\ConferenceSampleQt\ConferenceSampleQt\sioclient.lib(sio_socket.obj)
Any work around for the Error
Naresh
htnik_h_
Yes. It's required to made two dlls. Native dll compiled with static runtime labraries which will call woogeen classes and then managed C++ dll which will call native dll.
