Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
RabbitMQ Connectivity Problem
Choudhary__Shishir
After following the single server configuration from https://software.intel.com/en-us/articles/intel-collaboration-suite-for-webrtc I get RabbitMQ connectivity error.
I even installed rabbitMQ myself (because the installation guide does not talk about installing rabbit mq), however I still get below error.
What could be wrong ?
2018-12-04 22:01:40.901  - INFO: AmqpClient - Connection to rabbitMQ server error { Error: connect ECONNREFUSED 127.0.0.1:5672
    at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1191:14)
  errno: 'ECONNREFUSED',
  code: 'ECONNREFUSED',
  syscall: 'connect',
  address: '127.0.0.1',
  port: 5672 }
Second_Chan
ubuntu:
#hostname  localhost
#vi /etc/hosts
add
"127.0.0.1       localhost"
then restart rabbitmq
#sudo /etc/init.d/rabbitmq-server restart
Qiujiao_W_Intel
Did you install rabbitmq in a second device than where mcu modules are running? If so, you need to enable remote access in rabbitmq config as in https://www.rabbitmq.com/access-control.html :
This is configured via the loopback_users item in the configuration file.
If you wish to allow the guest user to connect from a remote host, you should set the loopback_users configuration to none. A complete RabbitMQ config file which does this would look like:
loopback_users = none
Or, in the classic config file format (rabbitmq.config):
[{rabbit, [{loopback_users, []}]}].
