Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
SIP Gateway with AndroidSDK
Matthew_G_1
Is it possible to use the WebRTC->SIP gateway with the Android SDK?  I see there are examples for using the gateway with the JS SDK, but I can't find any for using it with the Android SDK.
Chunbo_H_Intel1
Hi Matthew,
Currently no Android SDK for SIP gateway. But I have to confirm with you that is the Android SDK for WebRTC client, or Android SDK for SIP client.?
Matthew_G_1
I've been playing with developing an Android app using the Intel CS for WebRTC Android SDK -> this works well for building WebRTC applications.  However, if I also want my application to be able to communicate with legacy SIP networks, then I need to use the Intel CS for WebRTC Gateway, which works, but I can only find examples for integrating JavaScript based clients with, not the Android one.
Does that help clear up my question?
Chunbo_H_Intel1
Thanks for the explanation. But currently ONLY JS client is supported...
