Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
SIP connectivity
Bikbaev__Timur
hello community,
im trying to forward SIP calls from SIp provider to intel MCU, ive installed latest kamailio SIP server(5.1.3) and receive SIP calls there , also SIP user "mcu" created on kamailio side and calls goes there, but i need to register mcu under this user. there no configuration options in sip_agent.toml/sip_portal.toml . Maybe there some documentation exists about that?
Cheers
Qiujiao_W_Intel
Please open http://serverip:3300/console and input service sample service key and id (if you are using sample service and id in MCU), then click object in Room Detail->sip and set sip info and apply them, BTW, this configuration change will take effect 6s later when there is no stream published or subscribed in room.
Bikbaev__Timur
Thanks for response Qiujiao , but we still using mcu 3.5.2 without management console, is there any way to mention sip settings inside mcu configuration? or maybe you can give me some documentation to read?
Thanks in advance
Qiujiao_W_Intel
For 3.5.2,please open  http://serverip:3000/console and click SIP Connectivity and then enable sip to configure sip account
