Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Sample application is not working in MS Edge Browser
Nikhil_kumar__Doosar
Hello Team,
Sample web application(v4.1) is not working in edge ,we are getting error messages like (Failed to create MediaStream, NotFoundError)
Nikhil
YanbinZ_Intel
Hi, Nikhil
Could you please provide Edge version  and reproduce steps?
Yanbin
Hi Yanbin,
Simply we download the framework and started the MCU server in AWS.
Opened index.html from node server with port number 80 in in IE browser (v40.15063.0.0).  We got issue as "Failed to create media stream ".
We are not getting our local stream too and not asking for camera permissions,
Ics.Base.MediaStreamFactory.createMediaStream returns the fail response.
Nikhil
YanbinZ_Intel
Hi, Nikhil
 1. Could you please double confirm the camera can connected successful on Edge machine.
  2. If that works fine in step1,  please update Edge browser to 42.17134.1.0 or latest one.
Yanbin
Hi Yanbin,
Thanks for your reply edge version 42.1x is working fine , But in safari v12 we are  getting issue as "Receive remote stream without subscription". Our local stream is published successfully, and visible at other end.But at safari user end remote mixed stream is not subscribed.Please find below attachment for console log screenshot.
Nikhil
Any help would be appreciated.
Thank you.
Nikhil.
YanbinZ_Intel
Hi, Nikhil
 We also found this issue on our release testing cycle.  It seems the safari issue and related to machine hardware. It works fine on some of machines while works abnormally on others during our testing.  We will monitor safari related fix closely .
Yanbin
Hi Yanbin,
Thanks for your reply.
Nikhil.
Hi Yanbin,
i am using edge browser with 42.17134.1.0  but it is working in some systems(sample application 4.1) and not working in few systems with showing error log
ORTC18615: ORTC RTCDtlsTransport: DTLS handshake failed. hr=c004e00f. is it related to open ssl issue or any thing issue in client side or server side
Nikhil
