Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Stop Sharing Screen - Chrome Browser
emilija_n_1
Hi there,
in the basic example, we experience issue with share screen.
After i click share screen it shows stop sharing window from chrome, but when i click on that popup window share screen is not stopped is showing black window and not get in 'stream-removed' event or 'videoDisabled'.
Is this happening from new updates of chrome ?
Do u know why and what might be causing this issue , and any idea how can resolve this issue?
Jianjun_Z_Intel
Hi emilija,
Which version of Intel CS for WebRTC SDK are you using? Old versions may not work with the latest Chrome.
emilija_n_1
Hi, we are using version 3.2 Update 1.
Jianjun_Z_Intel
Cannot reproduce this issue. Is there any warning or error in the console?
When you click "Share Screen" button, it shows a screen sharing window picker. Then you can choose to share the entire screen or one of your applications. A bar appears at the bottom of screen during screen sharing. Clicking "Stop Sharing" stops the screen sharing stream.
emilija_n_1
Hi , there is no error in console or warning but happening in our project after click stop sharing is not stops the stream successfully. I find a solution how to handle with this problem but wanted to know if there is problem in basic example.
Thanks .
Jianjun_Z_Intel
When you click "Stop Sharing", browser stops the MediaStream. JavaScript SDK (conference mode, v3.2.x) listens on vidoe track's onended event, and unpublish this stream when onended event is fired.
