Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Test lab in Azure or AWS VM specs
Stephen_T_
HI,
I would like to do some testing with the intel WEBRTC stack, but would like to use a cloud environment like AZURE or AWS. Is this possible/supported and do you have any advice on the specs of VM's I should deploy please for a small test of a few clients. I wasn't clear if this platform only runs on the bare metal of certain intel backed hardware.
Many thanks
Steve
Lei_Z_Intel1
Yes, Intel CS for WebRTC support cloud VM deployment. AWS is validated, while Azure not tested yet. keep in mind to set the public ip address of VM for portal node and webrtc-agent node running on it.
