Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
The iOS framework file is too large
tangk
ver 4.0.2
The iOS framework file is too large.
It is too large compared to Android and other webrtc libraries.
ICS.framework 202MB
WebRTC.framework 749MB
Is there a way to reduce the file size?
Jianjun_Z_Intel
Hi Kim,
Your application would not be so large since unused symbols will be stripped. And these frameworks are large mainly because of three reasons. 1. Both of them support three architectures - armv7, arm64 and x86_64; 2. They are bitcode enabled; 3. They are static libraries.
tangk
Thank you Jianjun Z. I removed the x86_64 with the lipo command in the framework, but only a small amount. Could you share the framework that removed the bitcode?
