Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Video Call not supporting with High Resolution in iOS.
K__Srujan
Hi Team,
When creating ICSLocalStream we will initialise with ICSVideoTrackConstraints with HIGH SUPPORTED resolution w.r.t device compatibility. Now if we do init local stream with HIGH RESOLUTION the local stream is Pausing/ Stuck after 25-35 seconds, in SFU Mode.
Please find below code.
//// Code Starts ///////
let constraints = ICSStreamConstraints.init()
constraints.audio = true
constraints.video = ICSVideoTrackConstraints.init()
constraints.video?.frameRate = 24
constraints.video?.resolution = CGSize(width: 1920, height: 1080) // Supported maximum resolution..
constraints.video?.devicePosition = .front
var errorObj : NSError?
localVideoStream = ICSLocalStream.init(constratins: constraints, error: &errorObj)
////// Code Ends //////
Srrujan K.
K__Srujan
Hi Team,
Any update on the above?
K__Srujan
Hi Team,
Any update would be appreciated?
K__Srujan
Hi Team,
Any response would be appreciated?
Srujan K.
Jianjun_Z_Intel
Hi Srujan,
The highest resolution we tested is 1080p. We didn't test higher resolution because of performance and battery usage considerations.
