Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
WebRTC Server build
chaojun_w_
root@jun-KVM:/home/jun/Release-v2.5/bin# ./start-all.sh
Error: node not found. Please install node v0.10 first.
In accordance with the document configuration, the start.sh script to perform the wrong, and seeking solutions.
Chunbo_H_Intel1
Obviously, you will need to run "bin/init.sh --deps" first to install all the required third parties, like the node you mentioned.
chaojun_w_
I have been in accordance with the requirements of the document for the operation of the --deps bin/init.sh, the document referred to the plug also installed. But the certificate issue did not understand, the official download of the compressed package is not there is a certificate? Do I have to register a certificate or do other operations?
Chunbo_H_Intel1
When you mentioned certificate, do you mean the https related thing? If yes, we've already provided a valid certificate in the official download which is due to the end of October. But it is recommended in our release note, you'd better generate and use your own certificate  as the consideration of security.
Thanks!
