Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Which TCP/UDP ports requited to be opened inside the firewall
BIBHAS_B_
Hello Team,
We are facing some big challenges when we are inside the firewall where port security is implemented.
We opened all the required TCP and UDP ports but getting blank video.
We are seeing that when user join in conference some random TCP ports generated.
Please find the below netstat result & give us a solution which TCP/UDP ports requited to be opened inside the firewall.
[root@localhost ~]# netstat -tuplen
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10856      1/systemd
tcp        0      0 0.0.0.0:4369            0.0.0.0:*               LISTEN      990        19866      1502/epmd
tcp        0      0 0.0.0.0:42902           0.0.0.0:*               LISTEN      0          1048060    31637/./woogeen_aud
tcp        0      0 0.0.0.0:34135           0.0.0.0:*               LISTEN      0          1045724    31645/./woogeen_vid
tcp        0      0 0.0.0.0:2232            0.0.0.0:*               LISTEN      0          19709      1198/sshd
tcp        0      0 0.0.0.0:42943           0.0.0.0:*               LISTEN      0          1045720    31652/./woogeen_acc
tcp        0      0 0.0.0.0:5666            0.0.0.0:*               LISTEN      992        21550      1194/nrpe
tcp        0      0 0.0.0.0:38407           0.0.0.0:*               LISTEN      0          1047670    31652/./woogeen_acc
tcp        0      0 0.0.0.0:25672           0.0.0.0:*               LISTEN      990        18730      1487/beam.smp
tcp        0      0 0.0.0.0:27017           0.0.0.0:*               LISTEN      0          18691      1350/mongod
tcp6       0      0 :::111                  :::*                    LISTEN      0          10855      1/systemd
tcp6       0      0 :::8080                 :::*                    LISTEN      0          239806     30582/node
tcp6       0      0 :::4369                 :::*                    LISTEN      990        19867      1502/epmd
tcp6       0      0 :::3000                 :::*                    LISTEN      0          239481     30509/node
tcp6       0      0 :::2232                 :::*                    LISTEN      0          19711      1198/sshd
tcp6       0      0 :::3001                 :::*                    LISTEN      0          238498     31051/node
tcp6       0      0 :::443                  :::*                    LISTEN      0          238500     31051/node
tcp6       0      0 :::5672                 :::*                    LISTEN      990        19887      1487/beam.smp
udp        0      0 0.0.0.0:60660           0.0.0.0:*                           0          239855     30802/./woogeen_sip
udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1050906    2952/rpcbind
udp        0      0 10.10.200.166:50002     0.0.0.0:*                           0          1048825    31652/./woogeen_acc
udp        0      0 10.10.200.166:50003     0.0.0.0:*                           0          1048830    31652/./woogeen_acc
udp        0      0 0.0.0.0:1007            0.0.0.0:*                           0          1050907    2952/rpcbind
udp        0      0 0.0.0.0:46791           0.0.0.0:*                           0          239852     30797/./woogeen_sip
udp6       0      0 :::111                  :::*                                0          1050908    2952/rpcbind
udp6       0      0 :::1007                 :::*                                0          1050909    2952/rpcbind
Lei_Z_Intel1
Now TCP is used for internal stream transmission, UDP is used for external WebRTC connection. Both of them can be set through TOML configuration files. TCP port range config through [internal] and UDP port range config through [webrtc].
