Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
android how to publish unmixed stream
Somnus_Chen
Hi, javascript SDK, publish options {unmix:true}, but android SDK, there is no such config in PublishOptions.
By the way, I setResolution(1920, 1080), but the mixed remotestream only supported 640x480 or lower! Is this your limit or my wrong configuration?
He_Z_Intel
Which version did you use?
Somnus_Chen
3.5.2
    I found  N.API.createRoom can change the default resolution.    thanks a lot!
He_Z_Intel
you can use ConferenceClient.unmix to unmix a published stream.
