Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
error create token
aakin
I have  problem with MCU Server. When I try to run Woogen example( by putting url= localhost:3004/) I get an error in script2: create token.It is an error in he function create token. I am new in this webrtc world so sorry if my problem is not described as good as it should be. For my faculty  research I have to test conference room, but I can even star the conference.
My questions are:
1)do I need to change a .js file which are provided in this package? I changed parts with ip adresses etc.
2) for simple coference room test, should i start node basicServer or bin/start-all?
Thanks in advance
Chunbo_H_Intel1
For the simple conference test, you just need to run start-all.sh. But before that, you will have to run the init.sh script to setup all the dependency for MCU server.
Thanks!
