i am trying to use the same code from the sample app to get the services running on the server on my machine. but i get strange exception and no response from the server.
here is the log:
08-10 16:38:29.681 19313-19313/com.avidbeam.avbwebrtcconfclient I/SettingsFragment﹕ Getting Services 08-10 16:38:29.686 19313-19313/com.avidbeam.avbwebrtcconfclient I/SettingsFragment﹕ manager.getServices() 08-10 16:38:29.686 19313-19313/com.avidbeam.avbwebrtcconfclient D/WooGeen-ManagerClient﹕ GetServicess 08-10 16:38:29.686 19313-19313/com.avidbeam.avbwebrtcconfclient I/SettingsFragment﹕ java.lang.NumberFormatException: Invalid int: "3000services" 08-10 16:38:29.686 19313-19313/com.avidbeam.avbwebrtcconfclient W/System.err﹕ com.intel.webrtc.base.WoogeenException: java.lang.NumberFormatException: Invalid int: "3000services" 08-10 16:38:29.686 19313-19313/com.avidbeam.avbwebrtcconfclient W/System.err﹕ at com.intel.webrtc.conference.manager.ManagerClient$ManagerHandler.handleMessage(ManagerClient.java:578) 08-10 16:38:29.686 19313-19313/com.avidbeam.avbwebrtcconfclient W/System.err﹕ at android.os.Handler.dispatchMessage(Handler.java:102) 08-10 16:38:29.686 19313-19313/com.avidbeam.avbwebrtcconfclient W/System.err﹕ at android.os.Looper.loop(Looper.java:145) 08-10 16:38:29.686 19313-19313/com.avidbeam.avbwebrtcconfclient W/System.err﹕ at android.os.HandlerThread.run(HandlerThread.java:61)
here is the code that gets executed :
ManagerClient managerClient = new ManagerClient("http://196.202.104.102:3000", "545b9c625fb30a63624b83ba", "30703");
try {
Log.i(GlobalEntities.SETTINGS_FRAGMENT_TAG, "manager.getServices()");
servicesList = managerClient.getServices();
Log.i(GlobalEntities.SETTINGS_FRAGMENT_TAG, "manager.getServices() DONE"+servicesList.size());
for(int i=0 ; i<servicesList.size() ; i++){
serviceNamesList.add(servicesList.get(i).getName());
the second log does get executed.
Thanks in advance.
- Tags:
- HTML5
- JavaScript*
Our QA tried the same code and it works as expected. So the question is that what is the definition of 'servicesList' here?
And I suppose you're using the latest v2.5. Right?
