Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
iOS SDK [4.0.1] - Partcipant Join/Add Event
George__Nimi
I am using Client iOS SDK v.4.0.1.
In JS SDK we have 'participantjoined' which triggers when a new participant joins the RTC conference room. Similar to this, I saw this
- (void) conferenceClient: (ICSConferenceClient *)  client didAddParticipant: (ICSConferenceParticipant *) user // Triggers when a user joined conference. But seems to be not triggered.
Am I missing something here? Please guide me.
Is there an event that is triggered when a participant leaves a room similar to 'left' event in JS SDK?
The v.4.1.1 documentation states 'Subscribing streams with audio/video only option is not supported' in the known issues list. Is this the case with version 4.0 as well. I want to give an option to the user to subscribe to audio alone.
YanbinZ_Intel
participantDidLeave added in latest code and audio/video only supported as well . Please use latest code at Github https://github.com/open-webrtc-toolkit/owt-client-native.
George__Nimi
I have taken the latest code as mentioned and I am trying to build the same following the steps mentioned there. Meanwhile I have a doubt... I couldn't find any reference directly to this in the code I am using.
I am using the CS WebRTC Client SDK iOS.v4.0. I was working in reference to the conference sample provided. Where must this newly built (https://github.com/open-webrtc-toolkit/owt-client-native) owt native sdk be placed in reference to the sample code?
George__Nimi
I was able to build the latest at GitHub(https://github.com/open-webrtc-toolkit/owt-client-native). In the out folder I see a OWT.framework and WebRTC.framework. When I checked OWT header files, I see similar functions as in ICS.framework header. Should I replace this ICS framework with OWT framework?
As said earlier, I am using CS WebRTC Client SDK iOS.v4.0. I was working in reference to the conference sample provided there. Should I replace ICS references with corresponding OWT ones to resolve the issue?
I am new to this.. So any help would be great. Please guide me. Thanks.
Nimi
George__Nimi
Hi there,
Any update to this... Can you please give a reply? It would be really helpful for my project's advancement...
Nimi
