Very new at this technology. Was happy to see you guys release something to play with.
I am currently testing the sample app with the conferencing server. I am running into an issue when going to page xxx:3001/?room=e343fd322....
It tries to communicate to a socket.io instance at the INTERNAL address of the web server this software is running on. I have tried to set the public ip address of the server in all the config files I can find. Where is it pulling that internal address from?
Also is there any plans moving forward to have some sort of client for the IOS?
Thank you so much,
Alex
- Tags:
- HTML5
- JavaScript*
Hi Alex,
Thanks for your tryout.
For the multiple-server-ip case, you can use the"publicIP" variable in "runtime.config.json" file in conf folder in order to setup the right IP address for MCU server.
For the client in iOS, yes, we're moving towards that, and it will appear in future release.
Hi friend, WebRTC is available for c language?
JudLup!
Hi Judlup,
There is no C SDK in our solution currently.
Hi, I'm having the same problem in the latest version of the suite. When I connect through VPN the internal IP is used for socket.io communications when I navigate to https://publicip:3004. Where can I configure this?
Hi, do you mean that you want to set the socket.io server's address manually?
If so, you can edit the “ip_address" or "hostname" in the portal/portal.toml file
Hello Li,
I've tried doing this:
~/Intel/Release-v4.1$ bin/stop-all.sh
stopping nuve. stopping cluster-manager. stopping audio-agent. stopping conference-agent. stopping recording-agent. stopping sip-agent. stopping streaming-agent. stopping video-agent. stopping webrtc-agent. no management-console to stop no portal to stop stopping sip-portal no app to stop
Edited portal.toml, section [portal] to these bogus values:
[portal] keystorePath = "./cert/certificate.pfx" hostname = "test.com" #default: "" ip_address = "10.8.0.1" #default: "" # Port that the socket.io server listens at. port = 8080 #default: 8080 ssl = true #default: true
Then I started the Collaboration suite again:
~/Intel/Release-v4.1$ bin/start-all.sh
starting nuve, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-nuve.stdout
starting cluster-manager, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-cluster-manager.stdout
2019-01-28 10:27:15.389  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:15.403  - INFO: Main - Cluster manager up! id: 85041520
2019-01-28 10:27:15.404  - INFO: ClusterManager - Run as candidate.
2019-01-28 10:27:15.426  - INFO: ClusterManager - Someone else became master.
2019-01-28 10:27:15.428  - INFO: ClusterManager - Run as slave.
starting audio-agent, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-audio-agent.stdout
2019-01-28 10:27:16.899  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:16.945  - INFO: ErizoAgent - audio agent join cluster ok.
2019-01-28 10:27:17.005  - INFO: ClusterWorker - Join cluster woogeen-cluster OK.
2019-01-28 10:27:17.015  - INFO: ErizoAgent - as rpc server ok.
2019-01-28 10:27:17.021  - INFO: ErizoAgent - as monitoring target ok.
starting conference-agent, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-conference-agent.stdout
2019-01-28 10:27:18.158  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:18.176  - INFO: ErizoAgent - conference agent join cluster ok.
2019-01-28 10:27:18.188  - INFO: ClusterWorker - Join cluster woogeen-cluster OK.
2019-01-28 10:27:18.208  - INFO: ErizoAgent - as rpc server ok.
2019-01-28 10:27:18.213  - INFO: ErizoAgent - as monitoring target ok.
starting recording-agent, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-recording-agent.stdout
2019-01-28 10:27:19.647  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:19.668  - INFO: ErizoAgent - recording agent join cluster ok.
2019-01-28 10:27:19.694  - INFO: ClusterWorker - Join cluster woogeen-cluster OK.
2019-01-28 10:27:19.703  - INFO: ErizoAgent - as rpc server ok.
2019-01-28 10:27:19.705  - INFO: ErizoAgent - as monitoring target ok.
starting sip-agent, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-sip-agent.stdout
2019-01-28 10:27:20.446  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:20.470  - INFO: ErizoAgent - sip agent join cluster ok.
2019-01-28 10:27:20.482  - INFO: ClusterWorker - Join cluster woogeen-cluster OK.
2019-01-28 10:27:20.490  - INFO: ErizoAgent - as rpc server ok.
2019-01-28 10:27:20.492  - INFO: ErizoAgent - as monitoring target ok.
starting streaming-agent, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-streaming-agent.stdout
2019-01-28 10:27:21.455  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:21.483  - INFO: ErizoAgent - streaming agent join cluster ok.
2019-01-28 10:27:21.512  - INFO: ClusterWorker - Join cluster woogeen-cluster OK.
2019-01-28 10:27:21.526  - INFO: ErizoAgent - as rpc server ok.
2019-01-28 10:27:21.528  - INFO: ErizoAgent - as monitoring target ok.
starting video-agent, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-video-agent.stdout
2019-01-28 10:27:22.638  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:22.658  - INFO: ErizoAgent - video agent join cluster ok.
2019-01-28 10:27:22.688  - INFO: ClusterWorker - Join cluster woogeen-cluster OK.
2019-01-28 10:27:22.697  - INFO: ErizoAgent - as rpc server ok.
2019-01-28 10:27:22.702  - INFO: ErizoAgent - as monitoring target ok.
starting webrtc-agent, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-webrtc-agent.stdout
2019-01-28 10:27:23.883  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:23.904  - INFO: ErizoAgent - webrtc agent join cluster ok.
2019-01-28 10:27:23.914  - INFO: ClusterWorker - Join cluster woogeen-cluster OK.
2019-01-28 10:27:23.922  - INFO: ErizoAgent - as rpc server ok.
2019-01-28 10:27:23.924  - INFO: ErizoAgent - as monitoring target ok.
starting management-console, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-management-console.stdout
Start management-console HTTP server
events.js:183
      throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::3300
    at Server.setupListenHandle [as _listen2] (net.js:1360:14)
    at listenInCluster (net.js:1401:12)
    at Server.listen (net.js:1485:7)
    at Function.listen (/home/talentlab/Downloads/Release-v4.1/management_console/node_modules/express/lib/application.js:618:24)
starting portal, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-portal.stdout
2019-01-28 10:27:25.930  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-28 10:27:25.941  - INFO: Main - portal initializing as rpc client ok
2019-01-28 10:27:25.964  - INFO: Main - portal join cluster ok, with rpcID: portal-77adfa1f5d7f76ca9219@test.com
2019-01-28 10:27:25.964  - INFO: ClusterWorker - Join cluster woogeen-cluster OK.
2019-01-28 10:27:25.969  - INFO: Main - portal initializing as rpc server ok
2019-01-28 10:27:25.974  - INFO: Main - portal-77adfa1f5d7f76ca9219@test.com as monitor ready
starting sip-portal, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-sip-portal.stdout
starting app, stdout -> /home/talentlab/Downloads/Release-v4.1/logs/woogeen-app.stdout
When I navigate to http://10.8.0.1:3004 which currently displays the default Sample portal and check the Chrome developer tools to see which address socket.io connects to, it is still "192.168.178.123".
I see an exception occurring during startup, but I don't think this might be the problem? Although it does seem it isn't able to listen on some address/port.
Also, during stop-all.sh, I see the message "no portal to stop", so I might be jumping to conclusions to quickly, but it does seem portal.toml is not loaded because there is no portal running?
Help is appreciated! :)
Ah, it looks like its reacting to the change now after restarting the box. Stopping and starting the suite now results in correct behavior. Thanks for pointing me out to the correct configuration file.
