Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
the peer server can be used as turn/stun server ?
fengyee_y_
in the document of "Server User Guide", there is words in chapter 5.1:
The peer server is the default signaling server of the Intel CS for WebRTC. The peer server provides the ability to exchange WebRTC signaling messages over Socket.IO between different clients, as well as provides chat room management.
my question is: could the peer server also be used as turn/stun server when in my usage the client is behind NAT or firework?
Chunbo_H_Intel1
Those are two different things. Peer server is mainly a signaling server. Regarding TURN/STUN server, it's for the NAT traversal...
fengyee_y_
Hi CHUNBO H. thank you for your reply, after read some introductions about signaling and TURN/STUN, i know the difference now. then did Intel WebRTC have the TURN/STUN solutions?
Chunbo_H_Intel1
We provide the whole suite for free with TURN/STUN settings, but no constant TURN/STUN server provided. I suggest you setup your own TURN/STUN server according to RFC5766.
fengyee_y_
Hi CHUBO H.
in the sample files Intel provided, in file peercallff.html, there is codes shows below:
  var serverAddress = 'http://61.152.239.56:8095/';  // Please change it to signaling server's address.
  var p2p=new Woogeen.PeerClient({
    iceServers : [ {
      urls : ["turn:61.152.239.56:4478?transport=udp","turn:61.152.239.56:443?transport=udp","turn:61.152.239.56:4478?transport=tcp","turn:61.152.239.56:443?transport=tcp"],
      credential : "master",
      username : "woogeen"
      urls : "stun:61.152.239.56"
  });  // Initialize a Peer object
so we should install Intel Peer Server together with  TURN/STUN server  RFC5766 in the same machine, change the ip address in the codes above, then can we use both signaling and TURN/STUN, am i right?
Chunbo_H_Intel1
STUN/TRUN server and PeerServer can be deployed in the same machine or different machines.
fengyee_y_
Hi CHUNBO H.  i am reading the TurnServer documents you have mentioned, and will do the set up and have a try. thank you for your comments and helps.
Chunbo_H_Intel1
Great to hear that!
