Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
update 3.1 from 3.0 compile ERROR Multiple dex files define
snow__fly
update 3.1 from 3.0 later,ERROR in android 5.0 before:
Error:Error converting bytecode to dex:
Cause: com.android.dex.DexException: Multiple dex files define Lorg/webrtc/VideoCapturerAndroid$CameraErrorHandler;
:app:transformClassesWithDexForDebug FAILED
Error:Execution failed for task ':app:transformClassesWithDexForDebug'.
> com.android.build.api.transform.TransformException: com.android.ide.common.process.ProcessException: java.util.concurrent.ExecutionException: com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command 'D:\Program Files\Java\jdk1.8.0_60\bin\java.exe'' finished with non-zero exit value 2
Information:BUILD FAILED
But android 5.0 later no error.,run OK。
Chunbo_H_Intel1
Hi Snow,
We've never met this issue...
Please try to clean the environment and rebuild.
Thanks!
Modi__Vivek
I got the same error below API level 21.
