Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
webrtc3.4 ClusterManager "Invalid specified scheduling strategy: isp"
li_w_1
2017-07-05 17:09:54.820  - WARN: Strategy - Invalid specified scheduling strategy: isp , apply "randomly-pick" instead.
2017-07-05 17:09:55.041  - WARN: Strategy - Invalid specified scheduling strategy: isp , apply "randomly-pick" instead.
cluster_manager.toml:
[rabbit]
host = "localhost" #default: "localhost"
port = 5672 #default: 5672
[manager]
name = "woogeen-cluster"
#The time for cluster manager getting ready to handle the incoming 'schedule' requirements.
initial_time = 6000 #ms
#The interval of checking the attendences of all cluster workers.
check_alive_interval = 1000 #ms
#The threshold count of consecutive absences after which the corresponding cluster workers will be deleted.
check_alive_count = 3
#The default reservation time if not specified in the scheduling requirement.
schedule_reserve_time = 60000 #ms
[strategy]
general = "last-used"
portal = "isp"
session = "last-used"
webrtc = "isp"
sip = "round-robin"
avstream = "round-robin"
recording = "randomly-pick"
audio = "most-used"
video = "least-used"
Qiujiao_W_Intel
Hi, isp is not a strategy option for modules schedule,  MCU only support following strategies defined in cluster_manager.toml :
last-used, round-robin, randomly-pick,  most-used,  least-used
If you want to use isp features, following steps below:
1. configure isp and region value in portal/portal.toml  for portal module
2. configure isp and region value in webrtc_agent/agent.toml  for webrtc module
3. set isp and region in createToken  preference API, then this user's connection will be scheduled to portal and webrtc module that satisfied isp and region info
