Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
woogeen.sdk.js for changing GetUserMedia
Bipin_Kesharwani
We are trying to change optional parameters of GetUserMedia webrtc function in woogeen.sdk.js to add more functionality at client end, but because it is minified js file, it seems difficult. Could you please provide normal (non-minified) js file so that we can modify it. Or is there any alternate available for the same?
Artem_M_
It woul be great to get non-minified versions.
I used http://jsbeautifier.org/  to get some any alternative...
Chunbo_H_Intel1
For the local stream operation like GUM, we have encapsulated it into client SDK. It helps unify the stream operations on different platforms/OS.
For the optional parameters of GetUserMedia, you can just put them into the first parameter of WooGeen.LocalStream.create which will work as the original GUM API.
