Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1758 Discussions
Can't install pakages in intel devcloud
MohammadHaddy
I cant install packages like matplotlib and seaborn as
When I write !pip3 install seaborn --user then :
ERROR: Can not perform a '--user' install. User site-packages are not visible in this virtualenv.
When I write !conda create --name ml_project then:
/bin/bash: conda: command not found
VaradJ_Intel
Good day to you.
You can resolve the issue by activating the oneAPI environment before installing the package or creating the conda environment.
Please find the below command to activate the oneAPI environment:
source /opt/intel/inteloneapi/setvars.sh --force
Please make sure that the python used is "/glob/development-tools/versions/oneapi/<version>/oneapi/intelpython/latest/bin/python" using below command:
which python
If the issue still persists please let us know.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues.
Thank you!
MohammadHaddy
Firstly there is no folder named inteloneapi in /opt/intel/
and the second thing is that when i am writing which python, it's showing /usr/bin/python
mkopchenov
Hari_B_Intel
Hi MohammadHaddy,
I would like to confirm if you are using Intel DevCloud for the edge.
For your information, Intel DevCloud for the edge is designed to run an Inference application on Jupyter Notebook and submit jobs for different hardware to see the performance and extract data.
Unfortunately, the current Intel DevCloud for the edge still restricts the usual to install other software into the Intel DevCloud for theedge.
Hope this information help.
Thank you
Hari_B_Intel
MohammadHaddy,
This thread will no longer be monitored since we have provided a solution. Please submit a new question if you need any additional information from Intel.
