Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1703 Discussions
Can't view "View Training Modules" for Intel® oneAPI AI Analytics Toolkit
JohnWestlund
Trying to pull up the Training Modules Jupyter notebook, but I get this error:
 Cannot open Could not find path: Training/ML_101/ML_101.ipynbCannot open Could not find path: Training/ML_101/ML_101.ipynb
I don't have a "Training" directory in my home directory. Is this something I need to pull down from a git repo?
JaideepK_Intel
Could you let us know whether you are using Intel DevCloud for oneAPI or Intel DevCloud for the Edge or DevCloud for FPGA ?
Jaideep
JohnWestlund
Hi Jaideep,
I'm using DevCloud for OneAPI.
Best,
John
JaideepK_Intel
Can you please tell us which AI Analytics samples you are trying to run on DevCloud? so that we can walk you through the steps. Have a great day ahead.
Jaideep
JohnWestlund
From the following page: https://devcloud.intel.com/oneapi/get_started/
Under "Intel(r) oneAPI AI Analytics Toolkit" if I click "View Training Modules" it open the following link:
https://jupyter.oneapi.devcloud.intel.com/hub/login?next=/lab/tree/Training/ML_101/ML_101.ipynb?reset
That produces the error above.
JaideepK_Intel
Thank you for reporting this issue. We are going to inform our admin team about this.
Work around:
  • On the get started page, click on "Launch Jupyterlab."
Link: Get Started | Intel® DevCloud
  • Inside the oneAPI-samples folder, you can see the AI and Analytics folders. From there, you can access samples. Please check the below screen shots.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues.
Jaideep
JaideepK_Intel
Jaideep
JohnWestlund
Is the ML 101 notebook no longer available?
JaideepK_Intel
Thank you for your feedback. We will update our Get Started page. We have already sent you a private email from our side. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
