I tried to compile and run vector_add project on hardware in jupyterlab using following steps but failed. I put the tutorials I used below.
vector_add project is from https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/C%2B%2BSYCL/DenseLinearAlgebra/vector-add
However, after I submit the job to a Stratix10 node using the below command:
qsub -l nodes=1:stratix10:ppn=2 -d . -l walltime=24:00:00 build_fpga.sh, I found this job only run 1 minute.
Build files have been written to: /home/u208539/repository/DirectProgramming/C++SYCL/DenseLinearAlgebra/vector-add/build.
But no vector-add-buffers.fpga was found. the status while using "qstat" shows this job is finish.
Is there anything else I need to do? Any help would be appreciated!
I followed this tutorial.
1. Open the JupyterLab environment in Intel DevCloud for oneAPI.
2. Open a terminal window from the launcher window as explained above.
3. Clone the official oneAPI samples repository:
git clone https://github.com/oneapi-src/oneAPI-samples.git repository
4. Move to the vector-add sample directory:
cd repository/DirectProgramming/C++SYCL/DenseLinearAlgebra/vector-add/
5. Create a build_fpga.sh file in the directory with the following lines to compile and run the vector-add sample:
Building the vector-add sample for Stratix10 FPGA card:
mkdir build
cd build
cmake .. -DFPGA_DEVICE=intel_s10sx_pac:pac_s10
make fpga
6. Once the build_fpga.sh file is created, you can submit the job to a Stratix10 node using the below command:
7. The above command submits the job to a stratix10 node for building and running. This can take a couple of hours to complete. You can monitor the status of the job using the below command:
qstat
This will show if the job is in running state or not as shown below:
8. Once the job is complete, it will create two files, an output and error file, build_fpga.o<job_id> and build_fpga.e<job_id> which contains the output and error logs respectively.
You can find the vector-add-buffers.fpga application inside the build directory which can be run on a Stratix 10 node obtained using the command:
qsub -I -l nodes=1:stratix10:ppn=2 -d .
cd build
./vector-add-buffers.fpga
Thank you,
Wan
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
