Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1465 Discussions
FPGA compilation not working
murrtank
I have met a problem when trying to compile my code to FPGA. I get this error
aoc: Compiling for FPGA. This process may take several hours to complete.  Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets.  If the reports indicate performance targets are not being met, code edits may be required.  Please refer to the oneAPI FPGA Optimization Guide for information on performance tuning applications for FPGAs.
Error: The board package being used only supports report generation/emulation/runtime, please use the board package shipped in the FPGA addon instead.
Error: Exiting.
llvm-foreach:
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
I have seen similar problems here, but the solution given here (https://community.intel.com/t5/Intel-DevCloud/Cannot-find-board-package-on-devcloud/td-p/1421143) didn't work.
I'm using this command to get on a fpga_compile node.
qsub -I -l nodes=1:fpga_compile:ppn=2 -d .
Then I use this bash file,
source /opt/intel/inteloneapi/setvars.sh > /dev/null 2>&1
export PATH=/glob/intel-python/python2/bin:${PATH}
make clean
make build_fpga
which gives this compile command.
$(DPCPP_CXX) $(DPCPP_CXXFLAGS) -fintelfpga -Xshardware $(DPCPP_SOURCES) -o GEMM.fpga -reuse-exe=GEMM.fpga -Xsprofile -Xsboards=/opt/intel/oneapi/intel_a10gx_pac:pac_a10
 And then I get the error above
Can someone help me understand how to get this to work?
Rahila_T_Intel
Thank you for posting in Intel communities.
Could you please try the below suggestions.
you need to checkout the 2022.3.0 tag.
That will address the following error that you might encounter otherwise:
"fatal error: 'sycl/sycl.hpp' file not found"
This is just a temporary solution until the latest code changes are merged into the master branch.
$ git clone https://github.com/oneapi-src/oneAPI-samples.git
$ git fetch --all --tags
Fetching origin
From https://github.com/oneapi-src/oneAPI-samples
t [tag update] 2022.3.0 -> 2022.3.0
$ git checkout tags/2022.3.0
Checking out files: 100% (270/270), done.
Note: checking out 'tags/2022.3.0'.
$ git branch
* (HEAD detached at 2022.3.0)
 master
when compiling on an fpga_compile node, you need to specify an additional argument to the cmake command:
# for Arria10
$ cmake .. -DFPGA_BOARD=/opt/intel/oneapi/intel_a10gx_pac:pac_a10
or
# for Stratix10
$ cmake .. -DFPGA_BOARD=/opt/intel/oneapi/intel_s10sx_pac:pac_s10
This step is not necessary when compiling on a compute node that hosts a physical FPGA card such as Arria10 or Stratix10.
There are other samples not using cmake but just make instead, such as vector-add.
In this case, in order to compile on an fpga_compile node you need to make changes to the makefile.
Replace the following:
$(CXX) $(CXXFLAGS) -fintelfpga $^ -o $@ -Xshardware
with
# for Arria10
$(CXX) $(CXXFLAGS) -fintelfpga $^ -o $@ -Xshardware -Xsboard=/opt/intel/oneapi/intel_a10gx_pac:pac_a10
or
# for Stratix10
$(CXX) $(CXXFLAGS) -fintelfpga $^ -o $@ -Xshardware -Xsboard=/opt/intel/oneapi/intel_s10sx_pac:pac_s10
If you are still facing the issue, please let me know
1. The samples you are trying to run
2. The node number in which you are trying out the same.
Rahila_T_Intel
Fetching origin
$ git branch
 master
# for Arria10
or
# for Stratix10
with
# for Arria10
or
# for Stratix10
Rahila_T_Intel
We have not heard back from you. Could you please give an update?
murrtank
Hi, sorry! It seem to work now thanks for the help
Rahila_T_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
