QUESTION:
While using DevCloud am stuck with the precision of time stamps of job using qstat.
How to change the format of ctime from HH:MM:SS to HH:MM:SS and ms?
How to print ONLY the job duration into a file with millisecond precision?
Job Id: 271467.v-qsvr-1.aidevcloud
Job_Name = myjob
Job_Owner = *****@s001-n045
job_state = R
queue = batch
server = v-qsvr-1.aidevcloud
Checkpoint = u
ctime = Thu Sep 5 05:09:08 2019
Error_Path = s001-n045.aidevcloud:/home/*****/****/myjob.e271467
exec_host = s001-n047/0-1
Hold_Types = n
Join_Path = n
Keep_Files = n
Mail_Points = n
mtime = Thu Sep 5 05:09:11 2019
Output_Path = s001-n045.aidevcloud:/home/*****/****/myjob.o271467
Priority = 0
qtime = Thu Sep 5 05:09:08 2019
Rerunable = True
Resource_List.nodect = 1
Resource_List.nodes = 1:ppn=2
Resource_List.walltime = 06:00:00
session_id = 6709
Variable_List = PBS_O_QUEUE=batch,PBS_O_HOME=/home/****,
PBS_O_LOGNAME=****,
PBS_O_PATH=/glob/intel-python/python3/bin/:/glob/development-tools/ve
rsions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/
bin/intel64:/glob/development-tools/versions/intel-parallel-studio/com
pilers_and_libraries_2019.3.199/linux/mpi/intel64/libfabric/bin:/glob/
development-tools/versions/intel-parallel-studio/compilers_and_librari
es_2019.3.199/linux/mpi/intel64/bin:/glob/intel-python/python3/bin/:/g
lob/intel-python/python2/bin/:/glob/development-tools/versions/intel-p
arallel-studio/compilers_and_libraries_2019.3.199/linux/bin/intel64:/g
lob/development-tools/versions/intel-parallel-studio/compilers_and_lib
raries_2019.3.199/linux/mpi/intel64/libfabric/bin:/glob/development-to
ols/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/
linux/mpi/intel64/bin:/glob/intel-python/python3/bin/:/glob/intel-pyth
on/python2/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/hom
e/****/.local/bin:/home/****/bin:/home/****/.local/bin:/home/***/bin:/usr/local/bin:/bin,PBS_O_SHELL=/bin/bash,
PBS_O_LANG=en_US.UTF-8,
PBS_O_SUBMIT_FILTER=/usr/local/sbin/torque_submitfilter,
PBS_O_WORKDIR=/home/*****/****/
PBS_O_HOST=s001-n045.aidevcloud,PBS_O_SERVER=10.9.0.131
euser = *****
egroup =****
queue_type = E
etime = Thu Sep 5 05:09:08 2019
submit_args = myjob -F 0
start_time = Thu Sep 5 05:09:11 2019
Walltime.Remaining = 21598
start_count = 1
fault_tolerant = False
job_radix = 0
submit_host = s001-n045.aidevcloud
job_arguments = 0
ANSWER:
date +"%s.%3N" returns the current time with nanoseconds rounded to the first 3 digits, which is milliseconds in linux.
You can add the shell commands as in the example below to save the time taken to run your job in milliseconds to text file
eg:
cd $PBS_O_WORKDIR
STARTTIME=$(date +"%s.%3N")
<YOUR JOB SCRIPT CONTENT>
ENDTIME=$(date +"%s.%3N")
result=$(awk '{print $1-$2}' <<<"${ENDTIME} ${STARTTIME}")
echo $result >> time.txt
<YOUR JOB SCRIPT CONTENT> has to be replaced with the content of your job script
