Hi, I would like to access a node with 4th Gen Xeon processors, but I don't know what is the correct label for these devices. Could you please tell me how?
Usually, I start an interactive session for an "Gen9" GPU with this command: "qsub -I -l nodes=1:gen9:ppn=2 -d ."
Thanks in advance,
Leo
Thank you for posting in Intel communities.
The below highlighted is the property for the 4th Gen Xeon processor(sapphire rapids). You can use the label 'spr' for connecting.
There are two nodes present. You can use the below command to see if any of these nodes are available. Currently, they are in running status. Once they are available you can connect and use them.
pbsnodes | grep -i spr -B 4
If this resolves your issue, make sure to accept this as a solution. This would help others with a similar issue. Thank you!
Remya Premdas
Remya Premdas
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
![](/skins/images/2F496A9BF2E73260E2FDFDBCABF91248/responsive_peak/images/icon_anonymous_message.png)
