Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1518 Discussions
Industrial Worker Safety - Object Detection missing mobilenet-ssd.caffemodel
advanchip
I am taking
Intel® Edge AI Developer Certification
When ran "!downloader.py --name mobilenet-ssd -o raw_model" and got the error message
========== Downloading raw_model/public/mobilenet-ssd/mobilenet-ssd.caffemodel
... 0%, 90 KB, 598 KB/s, 0 seconds passed
########## Error: Downloaded file is shorter (92238 B) than expected (23147564 B)
FAILED:
mobilenet-ssd"
I only find mobilenet-ssd.prototxt , but not mobilenet-ssd.caffemodel in raw_model/public/mobilenet-ssd directory.
Please see attached and let me know how to get mobilenet-ssd.caffemodel in raw_model/public/mobilenet-ssd directory.
elaxman
Thank you, I followed the step and fixed the issue.
1. Copy the two  files
copy "https://github.com/chuanqi305/MobileNet-SSD/blob/master/deploy.prototxt" to
"raw_model/public/mobilenet-ssd/mobilenet-ssd.prototxt"
copy "https://github.com/chuanqi305/MobileNet-SSD/blob/master/mobilenet_iter_73000.caffemodel"
to "raw_model/public/mobilenet-ssd/mobilenet-ssd.caffemodel"
2. Comment the line
# !downloader.py --name mobilenet-ssd -o raw_model
3. Proceed
AndrewG_Intel
Hello @advanchip
We understand that you have some inquiries regarding Intel® Edge AI Certification. We have a forum for those specific products and questions so we are moving it to the Intel® DevCloud for Edge Forum so it can get answered more quickly.
Andrew G.
ChrisB_Intel
Thank you for the report. We are currently experiencing issues with mobilenet-ssd. It is currently being investigated. I will let you know when it is resolved, please let me know if you have any other concerns in the mean time.
Chris
advanchip
Hi Chris,
Any idea how long it will take to resolve?
ChrisB_Intel
Apologies for the delay. I do not have an ETA, it appears to be a download issues with model Zoo, we are trying to find a solution currently.
Chris
ChrisB_Intel
Apologies for the continued delay. We are still working on resolving this issue. However, you can download the file from here:
Then upload it, and it should work fine.
Please give it a shot and let me know if that works for you.
Chris
Pubudu_G_Intel
This error is still corrected at the Intel model zoo ?
ChrisB_Intel
Pubudu_G_Intel,
yes, there is still a problem downloading from Model Zoo. The workaround mentioned in the thread is the only current solution. Something more permanent is being worked on.
Chris
ChrisB_Intel
This issue should be resolved in the samples. Please take a look and let me know if you run into any issues.
Chris
advanchip
The issue still exists in both Certification Program and Tutorials. Please see attached screenshots and help fix it.
ChrisB_Intel
Thanks for the feedback, I had tested several of the other ones, but not this one. I am investigating.
Chris
ChrisB_Intel
Apologies for the delay on this. I have opened a bug with engineering on the tutorials.
Chris
advanchip
My Intel® Edge AI Developer Certification is still not working too.  Please see attached and open a bug on the certification program too.
ChrisB_Intel
The object detection tutorial should be now working as well. Please give it another shot and let me know if you run into any problems.
Apologies for all the problems you have run into.
Chris
JNorw
I just competed that object detection part in the training.  I opened a terminal in devcloud and  did
git clone https://github.com/chuanqi305/MobileNet-SSD
then copied the deploy.prototxt and mobilenet_iter_73000.caffemodel  to the raw model folder that the exercise used in that download execution.  I renamed them to the names it was looking for.  I commented out the download.
Then the model conversion to IR and the rest of the steps ran as expected in the certification ipynb.
elaxman
2. Comment the line
3. Proceed
advanchip
I followed the above instruction, it worked now.  Thanks
