Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1659 Discussions
Intel® Developer Cloud for the Edge - Bare-metal - Missing OneAPI Libraries
JasonPua
I have a customer interested in testing out IPEX with Pytorch on Intel Developer Cloud for the Edge on the bare metal instance.
It seems there is a node option with the config:
Intel Xeon D ProcessorIntel Xeon D processor D-2796NT (formerly code named Ice Lake)65 GBIntel® Data Center GPU Flex 170 (Discrete)None
CPU: d-2796nt
GPU: intel-data-center-gpu-flex-170
idc084
The IPEX library was installed with "pip"
# python3 -m pip install torch==1.13.0a0+git6c9b55e torchvision==0.14.1a0 intel_extension_for_pytorch==1.13.120+xpu -f https://developer.intel.com/ipex-whl-stable-xpu
Installation was successful with "pip show torch"
Version: 1.13.0a0+git6c9b55e
Summary: Tensors and Dynamic neural networks in Python with strong GPU acceleration
Home-page: https://pytorch.org/
Author: PyTorch Team
Author-email: packages@pytorch.org
License: BSD-3
Location: /home/u183618/.local/lib/python3.8/site-packages
Requires: typing-extensions
Required-by: accelerate, optimum, torchvision, triton
However once we tried importing torch on terminal with [python3 -c "import torch"], we are getting error that mkl libraries are missing.
OSError: libmkl_intel_lp64.so.2: cannot open shared object file: No such file or directory
Upon further checking I can see that the node idc084 has no OneAPI root as well.
ls /opt/intel/oneapi/
also returns missing error.
Does anyone from developer cloud team for the edge know if we can install OneAPI on those nodes?
JesusE_Intel
Hi JasonPua,
The Intel Developer Cloud for the Edge nodes do not have the Intel oneAPI Software Installed. If IPEX only requires pip packages you could try to setup a customer kernel with the required packages and submit the job to the node. If you need additional software outside pip packages I recommend using DevCloud for oneAPI.
Please take a look at this discussion where I provided instructions to setup a custom kernel:
https://community.intel.com/t5/Intel-DevCloud/Unable-to-import-pandas-after-activating-openvino-2022-2-0/m-p/1479334#M8003
Jesus
JesusE_Intel
Hi JasonPua,
Jesus
JasonPua
Hi there Jesus,
I've read through the documentation for IPEX and MKL libraries are certainly one of the prerequisites to run some AI Model training on the FLEX170 GPU. I've tried installing mkl via "pip install mkl" and exported the library_path to the MKL libraries but no cigar. So its certainly an outside pip packages situation.
Thank you for the pointers on the custom kernels though, that sure will come in useful.
Jason
JesusE_Intel
Hi JasonPua,
Any time! Please let me know if I can proceed to close this discussion. or if you have any additional questions.
Jesus
JasonPua
Yes sir, none for now.
Please proceed to close the discussion.
Thank you,
Jason
JesusE_Intel
