Hi
How can I open vtune-gui through devcloud? I get the following error:
m@optiplex:~$ ssh devcloud -Y
X11 forwarding request failed on channel 0
# Welcome to the Intel DevCloud for oneAPI Projects!
# 1) See https://devcloud.intel.com/oneapi/ for instructions and rules for
# the OneAPI Instance.
# 2) See https://github.com/intel/FPGA-Devcloud for instructions and rules for
# the FPGA Instance.
# Note: Your invitation email sent to you contains the authentication URL.
# If you have any questions regarding the cloud usage, post them at
# https://software.intel.com/en-us/forums/intel-devcloud
# Intel DevCloud Team
# Note: Cryptocurrency mining on the Intel DevCloud is forbidden.
# Mining will lead to immediate termination of your account.
Last login: Thu Mar 9 04:07:56 2023 from 10.5.0.46
Process exceeded login node resource limit.
Please run jobs on compute nodes using qsub or start an interactive shell using qsub -I.
Please visit the forums at: https://software.intel.com/en-us/forums/intel-devcloud
u187665@login-2:~$ vtune-gui
vtune-gui: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
u187665@login-2:~$
I don't know if that is problem with the devcloud or my own host machine. On my machine, libnss3 is installed.
m@optiplex:~$ dpkg -l | grep libnss
ii libnss-mdns:amd64 0.15.1-1ubuntu1 amd64 NSS module for Multicast DNS name resolution
ii libnss-mymachines:amd64 249.11-0ubuntu3.7 amd64 nss module to resolve hostnames for local container instances
ii libnss-nis:i386 3.1-0ubuntu6 i386 NSS module for using NIS as a naming service
ii libnss-nisplus:i386 1.3-0ubuntu6 i386 NSS module for using NIS+ as a naming service
ii libnss-systemd:amd64 249.11-0ubuntu3.7 amd64 nss module providing dynamic user and group name resolution
ii libnss3:amd64 2:3.68.2-0ubuntu1.2 amd64 Network Security Service libraries
ii libnss3-dev:amd64 2:3.68.2-0ubuntu1.2 amd64 Development files for the Network Security Service libraries
Any idea on how to fix that?
Thanks for posting in Intel Communities
For running VTune on the DevCloud, note the following:
1)VTune can’t be used with a GUI. This is by design and not a bug.
2)The Intel DevCloud is a cluster with no windows subsystem – much like any other HPC cluster out there.
You can use VTune Webserver Interface to access the GUI.
For your information the web server interface helps you quickly get started with the tool since you do not need to install VTune Profiler as a desktop application on every client system. You can use the VTune Profiler Server to configure and control analysis on arbitrary target systems and view collected results.
Please refer the below documentation for the detailed steps to use Intel® VTune™ Profiler as a web server in DevCloud:
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Thank you
Thank you
I followed the steps from the link you mentioned. Everything was fine up to accessing the interface through browser.
1- Running `qsub -I`.
2- SSHing to the compute node from another terminal.
3- Starting the web server and getting the URL.
Now, when I open Firefox and paste the link, I see the "set passphrase" page, but whatever I write and press OK, nothing happens. It doesn't proceed.
OK. The problem was fixed after some retires.
I will close the topic. Thanks for the support.
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
