Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1656 Discussions
Issue with Running MPI program on Intel devcloud
Garvita
I am running MPI sample program on intel devcloud cluster. It is running fine when executing on single node but facing trouble to use multi node cluster environment. Please suggest.
Number of processes is specified as 4 while running program with mpirun, expected rank information (rank 0,1,2, and 3) is coming on single node but on multinode only 2 processes are executed and also the rank information is incorrect.
- Execution on Single compute Node:
u171596@s001-n004:~/OneAPI_Project/intel_ci/mpiTest$ mpiicpc -cxx=dpcpp -fsycl mpiTest.cpp -o hello_mpi_dpcpp
u171596@s001-n004:~/OneAPI_Project/intel_ci/mpiTest$ cat mpiTest.cpp
#include <mpi.h>
#include<iostream>
#include<sched.h>
using namespace std;
int main(int argc, char** argv){
MPI_Init(NULL, NULL);
int rank;
int world;
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &world);
cout<<"Core "<<sched_getcpu()<<endl;
cout<<"Hello rank: "<<rank<< " world: "<<world<<"\n";
MPI_Finalize();
u171596@s001-n004:~/OneAPI_Project/intel_ci/mpiTest$ mpirun -n 4 ./hello_mpi_dpcpp
Hello world from host s001-n004 core 21 (rank 3)!
Hello world from host s001-n004 core 6 (rank 0)!
Hello world from host s001-n004 core 11 (rank 1)!
Hello world from host s001-n004 core 19 (rank 2)!
- Execution on multi Node Cluster using qsub utility:
u171596@login-2:~/OneAPI_Project/intel_ci/mpiTest$ cat distrjob2.sh
#PBS -l nodes=2:ppn=2
cd $PBS_O_WORKDIR
echo Launching the parallel job from mother superior `hostname`...
echo $PBS_NODEFILE
cat $PBS_NODEFILE
mpirun -machinefile $PBS_NODEFILE ./hello_mpi_dpcpp
u171596@login-2:~/OneAPI_Project/intel_ci/mpiTest$ qsub -l nodes=2:gpu:ppn=2 -d . distrjob2.sh
2107279.v-qsvr-1.aidevcloud
u171596@login-2:~/OneAPI_Project/intel_ci/mpiTest$ cat distrjob2.sh.o2107279
#      Date:           Tue 27 Dec 2022 08:19:26 PM PST
#    Job ID:           2107279.v-qsvr-1.aidevcloud
#      User:           u171596
# Resources:           cput=75:00:00,neednodes=2:gpu:ppn=2,nodes=2:gpu:ppn=2,walltime=06:00:00
Launching the parallel job from mother superior s019-n015...
/var/spool/torque/aux//2107279.v-qsvr-1.aidevcloud
s019-n015
s019-n015
s019-n016
s019-n016
:: oneAPI environment initialized ::
Hello world from host s019-n016 core 7 (rank 0)!
Hello world from host s019-n016 core 0 (rank 0)!
Error file : $ cat distrjob2.sh.e2107279
./hello_mpi_dpcpp: error while loading shared libraries: libsycl.so.6: cannot open shared object file: No such file or directory
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[2486,1],1]
Exit code: 127
VarshaS_Intel
Thanks for posting in Intel Communities and thanks for providing the details.
We have followed all the steps mentioned by you. But, we are able to get the expected results without any errors. For more details, please find the below screenshots(single and multi-node):
And also, could you please try re-running once again on multi-node by following these steps:
1) Could you please try changing the below line in the file distrjob2.sh(in order to check whether it is only on a particular node):
replace
it with
#PBS -l nodes=s019-n004+s019-n007:ppn=2
2) Next, run this command:
qsub distrjob2.sh
3) Then, the files will be generated. Do provide us with the results of both the error and output files. We have tried it with the nodes(s019-n015
s019-n016) but we are able to get the correct results.
Please do let us know if you are still facing the same error.
Thanks & Regards,
Varsha
Garvita
Thank you for your reply.
I am still facing the same issue.  Updated distrijob2.sh error and output files are pasted below.
u171596@s001-n007:~/OneAPI_Project/intel_ci/mpiTest$ cat distrjob2.sh
cd $PBS_O_WORKDIR
echo $PBS_NODEFILE
cat $PBS_NODEFILE
u171596@login-2:~$ cat OneAPI_Project/intel_ci/mpiTest/distrjob2.sh.o2112895
#      Date:           Mon 02 Jan 2023 11:02:45 PM PST
#    Job ID:           2112895.v-qsvr-1.aidevcloud
#      User:           u171596
# Resources:           cput=75:00:00,neednodes=s019-n004+s019-n007:ppn=2,nodes=s019-n004+s019-n007:ppn=2,walltime=06:00:00
Launching the parallel job from mother superior s019-n004...
/var/spool/torque/aux//2112895.v-qsvr-1.aidevcloud
s019-n004
s019-n007
s019-n007
:: initializing oneAPI environment ...
   bash: BASH_VERSION = 5.0.17(1)-release
   args: Using "$@" for setvars.sh arguments:
:: advisor -- latest
:: ccl -- latest
:: clck -- latest
:: compiler -- latest
:: dal -- latest
:: debugger -- latest
:: dev-utilities -- latest
:: dnnl -- latest
:: dpcpp-ct -- latest
:: dpl -- latest
:: embree -- latest
:: inspector -- latest
:: intelpython -- latest
:: ipp -- latest
:: ippcp -- latest
:: ipp -- latest
:: ispc -- latest
:: itac -- latest
:: mkl -- latest
:: modelzoo -- latest
:: modin -- latest
:: mpi -- latest
:: neural-compressor -- latest
:: oidn -- latest
:: openvkl -- latest
:: ospray -- latest
:: ospray_studio -- latest
:: pytorch -- latest
:: rkcommon -- latest
:: rkutil -- latest
:: tbb -- latest
:: tensorflow -- latest
:: vpl -- latest
:: vtune -- latest
Core 0
Hello rank: 0 world: 1
Core 3
# End of output for job 2112895.v-qsvr-1.aidevcloud
# Date: Mon 02 Jan 2023 11:02:50 PM PST
u171596@login-2:~$ cat OneAPI_Project/intel_ci/mpiTest/distrjob2.sh.e2112895
  Process name: [[15378,1],3]
  Exit code:    127
Garvita
@VarshaS_Intel Could you please help to resolve the issue.
JaideepK_Intel
Sorry for the delay, we are unable to reproduce your issue from our end. We informed the concern team, and we will get back to you with an update.
Jaideep
JaideepK_Intel
This is an account-specific issue, and the concerned team advised creating a new account and trying the same thing. If the issue still persists, please let us know.
Jaideep
Garvita
Thank you Jaideep.
It is working with different account.
Need one more information please. I am only able to use 2 nodes to execute the MPI program. for anything more,  it is giving "Resource Limitation" error. Is there any way I can use more than 2 nodes to execute the program?
JaideepK_Intel
In Devcloud, each user can access a maximum of two nodes, i.e., four processes per node.
There is no other way to access more than 2 nodes.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
Garvita
Thank You Jaideep
I tried with 4 processes per node. It seems only 2 are permissible. Please confirm.
JaideepK_Intel
Could you please try the above workaround suggested by @VarshaS_Intel ?
We were able to run with the above workaround.
Note (Work around 2):
>>In DevCloud, we can run a maximum of 2 nodes, and on each node we can run 2 processes (total of 4 processes).
Please follow the below steps:
Connect to the DevCloud via Cygwin using below command:
qsub -I -l nodes=<number_of_nodes>:<property>:ppn=2 -d .
example: qsub -I -l nodes=2:gpu:ppn=2 -d .
After logging into the compute node, we need to get the node numbers which we accessed. So run the below command.
echo $PBS_NODEFILE (example output looks like this: /var/spool/torque/aux//1955007.v-qsvr-1.aidevcloud)
We need to cat the output of $PBS_NODEFILE
example:
cat /var/spool/torque/aux//1955007.v-qsvr-1.aidevcloud
s001-n141
s001-n141
s001-n157
s001-n157
Copy the node numbers from above and paste them into the host file (I pasted the above node numbers into host.txt)
After pasting the node numbers into the host file, we can run the mpirun command. (Since I am running the mpi4py script, I gave the python command in the below command.)
mpirun -n 4 -hostfile host.txt ./test
If this resolves your issue, make sure to accept @VarshaS_Intel workaround as a solution. This would help others with a similar issue. Thank you!
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
