I followed the steps found in the FPGA devcloud documentations
And got to step 5.2 login script
I have successfully setup the .bashrc file to enable the devcloud_login command. However, after that, I could not setup an interactive node after typing the number for the required node type. This is the response I get from devcloud:
u163932@login-2:~$ devcloud_login -I S10PAC
For X2GO tunneling access. If connected to intel firewall, copy and paste the following text in a new mobaxterm terminal:
ssh -L 4002:s005-n005:22 colfax-intel
For X2GO tunneling access. For users NOT connected to intel firewall, copy and paste the following text in a new mobaxterm terminal:
ssh -L 4002:s005-n005:22 devcloud
running: qsub -q batch@v-qsvr-fpga -I -l nodes=s005-n005:ppn=2
qsub: waiting for job 36781.v-qsvr-fpga.aidevcloud to start
qsub: job 36781.v-qsvr-fpga.aidevcloud apparently deleted
I am not sure why the interactive job gets automatically deleted (highlighted in bold). After that the terminal returns me back to the login 2 node.
I am not an intel firewall user. Pasting the command "ssh -L 4002:s005-n005:22 devcloud" into a new linux system terminal results in login 2 node as well (no interactive access either).
Hi @bzha988,
Thank you for posting in Intel community forum and hope all is well.
Apologies for the inconvenient cause, there are multiple reason as mention scenario such as 1) job might be completed 2) execution time have reached.
The jobs does not look like a compilation task, would suggest to check what the jobs are performing.
Below are also a few references point for job submission and management, particularly the 'How to monitor jobs' or 'Querying Job Status'.
https://devcloud.intel.com/oneapi/documentation/job-submission/
https://devcloud.intel.com/oneapi/documentation/advanced-queue/
Hope that clarify.
Best Wishes
BB
Hi @bzha988,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.
Best Wishes
BB
Hi @bzha988,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
