I am using OneAPI. I am trying to change the conda environment to the one I created. But I am getting the following error.
Job submission
qsub -l nodes=1:ppn=2 test.sh
test.sh
echo "$(conda activate neuralmmo)"
python --version
test.sh.e2056343
CommandNotFoundError: Your shell has not been properly configured to use 'conda activate'.
To initialize your shell, run
$ conda init <SHELL_NAME>
Currently supported shells are:
- bash
- fish
- tcsh
- xonsh
- zsh
- powershell
See 'conda init --help' for more information and options.
IMPORTANT: You may need to close and restart your shell after running 'conda init'.
I even tried doing conda init bash but did not work.
But when I try to activate it in interactive mode it works.
(intelpython-python3.9) u178728@s001-n007:~/nmmo$ qsub -I -l nodes=1:ppn=2
qsub: waiting for job 2056348.v-qsvr-1.aidevcloud to start
qsub: job 2056348.v-qsvr-1.aidevcloud ready
# Date: Fri 25 Nov 2022 10:42:04 AM PST
# Job ID: 2056348.v-qsvr-1.aidevcloud
# User: u178728
# Resources: cput=35:00:00,neednodes=1:ppn=2,nodes=1:ppn=2,walltime=06:00:00
u178728@s001-n061:~$ conda activate neuralmmo
(neuralmmo) u178728@s001-n061:~$
Please help. Or how to quite the interactive environment without stopping the job because the job ends when doing logout. Either one can help!
Good day to you.
The command "conda activate <env_name>" is intended to be used for interactive shell sessions. This is a limitation of conda. It cannot be used in scripts.
If you wish to activate your conda environment in script, you need to hook conda to your shell as given below in the job script:
eval "$(conda shell.bash hook)"
conda activate myenv
python --version
(See attached screenshot for reference)
If this clears your query, kindly click the “Accept as Solution” button to indicate that your issue is resolved. This will also help others with a similar issue.
Thanks and Regards,
Jyothis V James
Good day to you.
python --version
Thanks and Regards,
Jyothis V James
Glad to know that your issue is resolved. We will no longer monitor this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Jyothis V James
