Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Spawn Failed
NathanChen
I tried many times to restart the server that always showed "spawn failed".
UserID = u128541
Thanks for help
ChrisB_Intel
I was just going to ping you and ask, we made a change last night, so glad that resolved it. I will go ahead and close this out, but let me know if you need anything further.
Chris
ChrisB_Intel
My apologies for the issues. I ran several tests and everything seems to be working correctly. Can you re-run your test from an incognito browser and let me know the result? If it continues to not work, can you let me know what screen you are on right before you get this error?
Chris
NathanChen
Hi Chris,
That still did not run when I re-run from an incognito browser on Windows and Linux. But, I use my colleague's account that can work.
Nathan
ChrisB_Intel
Apologies for the problems, I have opened a bug with the developers so hopefully we can get this resolved quickly. I will keep you updated.
Chris
ChrisB_Intel
Apologies for the delay, It looks like the issue is being caused conflicting packages in ~/.local. Please open a terminal and remove the directory ~/.local or rename it and try again.
Please let me know the result.
Chris
NathanChen
Hi Chris,
1.I do not understand how can I open the terminal from the DevCloud because the jupyter server did not work on my DevCloud.
2. I renamed the ~/.local did not succeed If it is means host terminal.
Nathan
ChrisB_Intel
Okay, yup I should have totally thought about that before I asked. My apologies, working on this from my end right now.
Chris
NathanChen
Hi Chris,
Thank you for your kindly help that is working.
Nathan
ChrisB_Intel
Chris
dtoya04
I am also facing error with the message "spawn failed"  when I start JupyterLab and samples on DevCloud.
Could you please help for my case? My id is u135672.
Toya
