Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1474 Discussions
Unable to connect to devcloud
PrasannaIITM
I am not able to connect to devcloud. I get the following error:
kex_exchange_identification: Connection closed by remote host
Connection closed by UNKNOWN port 65535
I could connect to devcloud using the command ssh devcloud until yesterday.
JaideepK_Intel
Hi
Thanks for your patience. The issue via SSH is fixed now. Could you please check from your end and let us know if the issue still persists?
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
FelipeML
I have the same problem since yesterday.
Navaneeth
I am facing the same problem as well.
JaideepK_Intel
We are also facing a similar issue. We are working on this internally and will get back to you with an update.
Jaideep
PrasannaIITM
JaideepK_Intel
Hi
Jaideep
JaideepK_Intel
Hi
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
