Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1345 Discussions
Unable to connect via ssh
alazzaro
I did the setting this morning to get access to the devcloud via ssh (https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/). However, after 1h I'm still getting:
> ssh devcloud
u155076@devcloud: Permission denied (publickey).
Is there a delay to propagate the public key on the system?
AthiraM_Intel
Thank you for posting in Intel communities.
Could you please download the "setup-devcloud-access-xxxxx.txt" file again and try connecting DevCloud?
Your issue might be due to corrupted ssh key. Also make sure that the path to config is correct.
Also please let us know whether you are able to connect jupyter lab?
AthiraM_Intel
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
