Hi, everyone. I am studying the 'BenchmarkApp_python' on JupyterLab. It's not clear which device is used for the implementation. Here's the code they used for the hardware inference.
# import necessary libraries
import json
import qarpo
# load job configurations for demo
with open('job_config.json') as json_file:
data = json.load(json_file)
# create and run the user job interface
job_interface = qarpo.Interface(data)
job_interface.displayUI()
It's not clear which hardware will be used for inferencing. Can you guys please help me out? Thank you for your time.
Hi rico22,
In the BenchmarkApp Tutorial notebook, section 1.2 should display the targeted architectures and devices (see screenshot below). From the menu, you should be able to select a GPU. Please let me know if this works for you.
Jesus
Hi Rico22,
May I know which tutorial or repository are you referring to?
Referring to Basic Usage in Benchmark Python Tool, the application will load the specified model onto the CPU and perform inferencing on batches of randomly generated date inputs for 60 seconds.
Hope it helps.
Wan
Hi, Wan. Thank you for your response. Here's the link I am following:
The job script doesn't indicate which device it is using. I would like to do inferencing on GPU. What should I do? Thank you.
Hi rico22,
Jesus
Thank you for your response. I appreciate it. Have a nice day.
