Since this sunday, command getquota does not work for me.
It send POST request to http://login-1:898/ and wait answer forever.
Please check.
- Tags:
- General Support
Thanks for reaching out to us,
We will contact our DevCloud Admin team and let you know.
Could you please let us know whether the issue is resolved now?
Unfortunately, not completely.
It does not work on login node:
Last login: Thu Dec 26 21:26:30 2019 from 10.9.0.249 u32955@login-1:~$ getquota curl: (7) Failed to connect to login-1 port 898: Connection refused u32955@login-1:~$ ifconfig ens5: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.9.0.1 netmask 255.255.128.0 broadcast 10.9.127.255 inet6 fe80::5054:ff:fe09:1 prefixlen 64 scopeid 0x20<link> ether 52:54:00:09:00:01 txqueuelen 1000 (Ethernet) RX packets 555927952 bytes 2866226633646 (2.8 TB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 5303458484 bytes 7894273512823 (7.8 TB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
but it works from interactive session:
# Resources: neednodes=1:fpga_compile:ppn=2,nodes=1:fpga_compile:ppn=2,walltime=06:00:00 ######################################################################## u32955@s001-n147:~/Projects/compile_tf_graph$ getquota 86.98 GB out of 200.00 GB (43.49%) used u32955@s001-n147:~/Projects/compile_tf_graph$
Hello, I have the same problem. Have you solved it?
The issue is resolved now. Could you please confirm the same from your end.
Yes! I confirm that the problem is resolved!
u32955@login-1:~$ getquota 88.35 GB out of 200.00 GB (44.17%) used u32955@login-1:~$ u32955@s001-n147:~$ getquota 88.35 GB out of 200.00 GB (44.17%) used u32955@s001-n147:~$
Thanks for the confirmation,we are closing the case.
