I was hoping to experiment with hpat on the system, getting ready for data-intensive work in the cloud. However, I do not see it installed and even the preset channels do not include the module even though it is on the Intel channel on Anaconda, albeit with a 'test' label.
Please let me know if you could get hpat to work.
- Tags:
- General Support
Kindly follow below steps to get hpat installed in a conda environment :
conda create -n env_hpat -c intel python=3.6 source activate env_hpat conda install -c intel -c intel/label/test hpat
Try to import hpat from python terminal.
Hope this helps.
Hope this helps.
Thanks, this sounds cool.
I must be confused by the setup though — if I installed everything from a terminal, why can't activate the environment in a new notebook?
!source activate env_hpat
gave me
/bin/sh: 1: source: not found
Kindly follow below steps to use your conda environment from jupyter notebook :
Activate the conda environment from the terminal.
Install ipykernel
conda install ipykernel ipython kernel install --name env_hpat --user
Now open the jupyter and select the "env_hpat" from Kernel option. ( path : jupyter -> kernel -> change kernel -> env_hpat)
Hope this works !!
Thanks again, so far so good!
Btw, a bland `conda update conda` before everything else failed, even though it attempted to update a surprising number of packages. (DevCloud promised to keep us on the bleeding edge, but you must know if some things are unstable or incompatible with other things.)
EnvironmentNotWritableError: The current user does not have write permissions to the target environment.
environment location: /glob/intel-python/versions/2018u2/intelpython3
uid: 34333
gid: 34333
Hope your initial query was resolved.
Kindly raise a new thread for your new query.
Please confirm whether issue related to hpat on devcloud is resolved, so that we can close it !!
Solved, please close the ticket.
This issue had been resolved and the thread is now closed. If you have a similar question, please start a new thread
