Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1659 Discussions
question about job script submit and validate on Intel devCloud
Saharsa
At first, thank you that every time you response my questions very fast.
I wrote two job scripts, one of them is compilation and the other one is execution.
Compilation script:
#!/bin/bash
dpcpp main.cpp -lsycl -lOpenCL -tbb -o a.out
Execution script:
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh
echo
echo start: $(date "+%y%m%d.%H%M%S.%3N")
echo
./a.out
echo
echo stop: $(date "+%y%m%d.%H%M%S.%3N")
echo
at first, I submitted my compilation job script in a queue, and then I submitted the execution one. but when I executed
bash job.sh
which is the execution script, it troughs an error which is not exist a.out file.
and it was correct.
so, every time after submitting my compilation script in a queue I used
bash complition.sh
and then I submited the excution script and validated it.
my question is: is there other solution to avoid doing every time
bash compilation.sh
after submitting it in a queue?!
I am not sure my compilation script is correct!
RahulU_Intel
Thanks for posting in Intel forums.
We looked into your case. The "a.out not found" error is because you have not provided the path to that file in the execution script. Please follow the below steps to run both compilation and execution file one after other automatically.
Step- 1: Create a script for compilation
$ vi compile.sh
Add the below code to the file and save:
#!/bin/bash
Step- 2: Create a script for execution
$ vi execute.sh
#!/bin/bash
echo
echo
cd $PBS_O_WORKDIR = <path to working directory>
./a.out
echo
echo
Step- 3: As mentioned in the previous query,
https://community.intel.com/t5/Intel-DevCloud/How-to-submit-two- different-job-scripts-to-queue/m-p/1290673#M2448
Create the common script to call this jobs as below:
$ vi submit_job.sh
You can give the below commands in the script and save.
#!/bin/sh -f
FIRST=$(qsub compile.sh)
echo $FIRST
SECOND=$(qsub -W depend=afterany:$FIRST execute.sh)
echo $SECOND
Step- 4: You can run the submit_job.sh using the below command,
                "./submit_job.sh"
You can use the command "qstat" to view the status of the job submitted. After successful execution of the job you will see the file compile.sh.oxxxxxx, compile.sh.exxxxxx and execute.sh.oxxxxxx, execute.sh.exxxxxx. '.o' is the output file and '.e' is the error file and 'xxxxxx' is the queue.
(You can find the queue when you do qstat)
Hope this helps.
Rahul
Saharsa
Thank you for you reply, but your solution does not work.
I found one solution for my problem, which is I creates a script which creates my job script. with I could submit my job and see the result of executing my code on CPU or on GPU.
RahulU_Intel
We haven't heard back from you. Could you please confirm if your issue is resolved.
Saharsa
RahulU_Intel
We are glad that your issue is resolved. We are closing this case. If you need any assistance you can post a new question.
