Could you please help me why I have this error:
qsub: submit error (Job exceeds queue resource limits MSG=cannot locate feasible nodes (nodes file is empty, all systems are busy, or no nodes have the requested feature))
when I try to submit my job on queue for executing it on CPU it through this error, instead for GPU all fine.
Could you please share the command used?
Meanwhile could you please try the below command to submit the job:
qsub -I -l nodes=s001-n038:ppn=2 job
Instead of s001-n038 ,you can select any available cpu nodes.
You can find the available nodes using the command:
pbsnodes
If the issue still persists, please let us know.
pbsnodes
Thank you for your response. my mistake was
nodes=1:cpu
and when I changed to nodes=1:gpu, it works.
because I wanted to submit my job to executing on CPU, so because of this I put CPU.
Is your issue resolved?
Thanks for accepting our solution. If you need any additional information, please submit a new question as this thread will no longer be monitored.
