Hey!
I have been using dev cloud for some time but right now when I try to run the following commands
watch -n 1 qstat -n -1
I see these error messages:
socket_connect_unix failed: 15137
qstat: cannot connect to server (null) (errno=15137) could not connect to trqauthd
qstat: Error (15137 - could not connect to trqauthd)
I also tried using commands like qsub, qdel and I see similar errors. What should I do to make these commands work again? My user ID is u194955.
Thanks in advance,
Thayna
I am having the same exact issue, with the same exact error code, when using qstat or qsub.
My Devcloud user ID is u177524.
Thanks in advance, too,
MDCC
Thank you for posting in Intel communities.
We are sorry for the inconvenience caused. We are checking with the concerned team on the same and will get back to you with an update shortly.
Sreedevi
Same here with `qsub` since yesterday.
$ qsub -I -l nodes=1:gpu:ppn=2 -d .
qsub: cannot connect to server (null) (errno=15137) could not connect to trqauthd
and with `qstat`
$ qstat
I have exactly the same issue:
qstat
Process exceeded login node resource limit.
Please run jobs on compute nodes using qsub or start an interactive shell using qsub -I.
Please visit the forums at: https://software.intel.com/en-us/forums/intel-devcloud
At the bottom it asks to use interactive shell however the result is the same:
qsub -I -l nodes=1:spr:ram1024gb:ppn=2
I'm facing the same issue!
qstat
My user id is u199996
I can reproduce this issue as well. It would be worth knowing if the entire Intel DevCloud batch system is offline, or if this only affects certain users.
Hello.
The issue seems to have been fixed on my end now. Just a heads-up for everyone, in case they want to check again.
MDCC
It started to work on my end too, however it would be good to know the issue for future references.
Palina.
@Thayna: The issue has been resolved. Can you please verify from your side?
@mspro, @kenji-yamane, @user_01: Can you please check and verify from your side if the issue has been resolved?
@Mdcc_UVa, @Palina: Glad to know that your issue is resolved. If you need any additional information, please post a new question.
Sreedevi
"Can you please check and verify from your side if the issue has been resolved?" - This issue is resolved for me. I can now connect to the PBS batch job system again.
It's been resolved on my side as well, thanks!
Hi @Thayna,
We have not heard back from you. Could you please give us an update? Is your issue resolved?
Sreedevi
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Sreedevi
