DSA said there was 3 updates required. I downloaded the 3 updates AND ALL 3 COSTANTLY FAILED TO INSTALL ....... WHY??????????????????????????????????
Do not be afraid to release the CAPS LOCK.
Aside from the multitude of problems DSA has, you told us absolutely nothing about your system.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
