Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1521 Discussions
zeInit() fails with ZE_RESULT_ERROR_UNINITIALIZED on s017-n001
Brice1
Hello
I am on node s017-n001. This is quad-GPU node where I am using oneAPI L0 for hwloc development. My code has been working fine on other nodes, but it fails in the very first  L0 API call on this node: zeInit() returns error ZE_RESULT_ERROR_UNINITIALIZED (0x78000001).  The documentation says it means the driver is not initialized but I am not sure if that means the kernel driver (i915 module is loaded) or some user-space L0 driver.
$ dpkg -l | grep level-zero | cut -c5-70
intel-level-zero-gpu 1.3.24420+i504~u20.04
level-zero 1.8.5+i504~u20.04
On a working node, packages are i815 instead i504, not sure if it matters.
intel-level-zero-gpu 1.3.24055+i815~u20.04
level-zero 1.8.5+i815~u20.04
level-zero-dev 1.8.5+i815~u20.04
By the way, level-zero-dev is missing on s017-n001. I reported the issue in the past and was told that it's only available on GPU-nodes, which should be the case here.
Rahila_T_Intel
We are able to reproduce the issue on the node s017-n001 and have informed the concerned team regarding this.
Could you please let us know the node numbers in which you are able to run the same successfully?
Brice1
Hello
It works on all non-NDA nodes with GPUs I could test recently, this includes s019-n012, s001-n157, s001-n141 this morning.
Brice
Rahila_T_Intel
Sorry to inform you that the node s017-n001 is work in progress and it will not be accessible.
Rahila_T_Intel
Hope your query got clarified. Could you please confirm whether we can close the case?
Brice1
Hello. I don't see where anything got clarified. Both s017n001 and n002 are both "state = down,offline" since I reported this issue. I know some oneAPI developers are looking at it but I am not aware of any fix yet. This issue is certainly not resolved yet.
Rahila_T_Intel
We are working on this internally and will share you the updates.
Rahila_T_Intel
Hi.
Please be informed that quad nodes will become available early Q1 2023.
Hope this will clarify your query.
Please let us know if we can close this case.
Brice1
Ok, thanks.
Rahila_T_Intel
Thanks for confirming. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
